Hi there,
I have some big numbers and I looked for a thousand separators, similar to decimal separator, but i dind´t find it in the options panel aside from the automatic units. Is it possible?
edit 1: You can get thousands separator with Unit → None → Locale format, but
Is it possible to change “,” separator for “.” separator? I mean, to visualizate “123.456.789” instead of “123,456,789”. I tried changing the time setting to “Europe” but still remains with “,” separator.
edit 2: I found a feature request in Github:
It seems it is a common problem with the community trying to solve it, looking to be implemented.
Thx for any help, J
