Hello
Can I install ZFS monitoring on grafana.net? Or are we still limited to the predefined set of integrations?
Hello
It’s possible. You should read docs more carefully.
Hi!
While there is not a pre-packaged ZFS Monitoring Integration on Grafana Cloud, you can host and visualize your ZFS metrics in Grafana Cloud by doing the following:
Use a Prometheus ZFS Exporter to export your metrics into a local Prometheus.
Remote_write those Prometheus metrics to the Grafana Cloud hosted Prometheus endpoint as documented here: Ship Metrics and Logs | Grafana Labs
Import this community dashboard for visualizing ZFS exporter Prometheus metrics in Grafana: ZFS dashboard for Grafana | Grafana Labs
