as you can see I have 4 ‘measurements’
2 of those needs to be on the left axis, and the other 2 needs to be on the right axis.
but I dont need 2 different right Y axises… I want only one right one for both measurments… how can i solve this?
The problem I have is that I am having 2 right Y-axis now…
so now I have 1 Left Y-axis (used for 2 measurements)
and i have 2 right Y-axis (1 Yaxis for each meausrement that should be displayed on the right Y-axis)
instead of 2 Right Axis, it should be only 1 Right Y-axis (used for both my measurements displayed on the right Y- Axis)
Ah, now I see what you mean. Someone else will need to answer this, because
it’s clearly a result of the new graph panel in Grafana 8 (as you say, this
used to work as you wanted it in Grafana 7), and I’m not up to speed on that
yet.
I think the clarification will help someone (hopefully) point at what you can
do.
that is correct, I have 2 (or more) measurements for right axis (Speed SP Auto / Speed SP Manual in this case)
I want both of them.
but now i have 2 times the Y axis, I only want 1
yes,
you have to make sure that all the ‘Overides’ you selected for the measurments that you placed on the right axes are the same… so for all your measurements on the right axis, you need to create all the overides you need and put everything on the same value (min, max, placement, unit, …)
Yes, that works but have you found a way to make it work with auto-scaling enabled?
I would like to make 2 measurements share the same axis scale or link their axis scales so they change together.
Regards,
