7.0 on system Linux -
I would like to use 2 Y axis because some data have max values = 10 and other are percentages. -
I’m using the method .inside the dashboard.new().addPanel(). Currently the data comes from a SQL query. All the data is displayed but some data are near the 0 because others are much greater. -
I would like the use a 2nd Y axis -
`.addPanel(
"title": "Test Campaing Passed",
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": data_source,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 10,
"w": 24,
"x": 0,
"y": 24
"hiddenSeries": false,
"id": 6,
"legend": {
"alignAsTable": 1,
"avg": true,
"current": true,
"max": true,
"min": true,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"nullPointMode": "connected",
"options": {
"alertThreshold": true
"percentage": false,
"pluginVersion": "8.4.1",
"pointradius": 2,
"points": true,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"datasource": sql_data_source,
"format": "time_series",
"group": [],
"metricColumn": "none",
"rawQuery": true,
"rawSql": sql_testcampaigns_passed,
"refId": "A",
"select": [
"params": [
"value"
"type": "column"
"timeColumn": "time",
"where": [
"name": "$__timeFilter",
"params": [],
"type": "macro"
"thresholds": [],
"timeRegions": [],
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:349",
"format": "short",
"logBase": 1,
"show": true
"$$hashKey": "object:350",
"format": "short",
"logBase": 1,
"show": true
"yaxis": {
"align": false
The SQL query contains 3 datas:
Test Campaign count
Test Campaign passed
Test Campaign passed percentage.
This last one, I would like to use the 2nd axis
- Did you follow any online instructions? If so, what is the URL?
I didn’t find revelent documentation
Thanks.
