Upgraded to v7 - Clock panel Bg Color STILL not working
I have seen reports of the Clock panel background color not working in previous releases. I assumed it would be fixed with v7 but it seems not. Any chance this can be fixed in a future release?
I found out this issue was fixed in clock-panel 1.1.1 but it did not update to that version automatically with an update to Grafana v7 due to another bug. But the devs have now fixed that issue so I can confirm as of 22 May 2020 grafana-cli plugins update-all will update the clock panel correctly (to the current 1.1.1 version).
Oh my… it does work, but you have to click the invisible bullet left to the words “Pick Color” (I suspect that is initialized with background color, which makes it by definition invisible). :slight_smile:
where do you see those words ???
In clock version V1.2.0 is the same background error again
